Fitting HKS BOV (old style)
Started by D2BBA, February 08, 2006, 11:08:55 AM
D2BBA
Hi folks,
Can anyone help me with this quick question?
I’m just about to fit a second hand HKS DP BOV to my FD.  The BOV came as you see it pictured.  It was fitted to an FD prior.
Everything seems straight forward, except the second “nipple” as pictured.  I cant find a vacuum line to attach.  Is this just left free,  I presume in this case the kit is adaptable for other cars.
If you can check the pic and put my mind at rest before fitting.
Ta
Chris
D2BBA
MillSpeed
I\'ve got this exact dump valve on my car, but it\'s at my folks place so I can\'t check. From memory, it uses the one vaccum feed with a t-piece to supply both nipples.
D2BBA
Ahaaaaaa!
Sounds like a plan!  Dont suppose you will be back at your folks to check in the next 5 weeks will you matey?  Mine will be out of the bodyshop and in need of some serious driving by then :)
Ta
Chris
MillSpeed
Most certainly will, I\'ll sus it out and get back to you.  :wave
MillSpeed
#5
Hiya mate,
hokay, just had a look at how my dump valve is set up....as I thought it\'s got a single vacuum line coming from one of the nipples (oo er) on the UIM, with a t-piece supplying both nipples on the dump valve. I took some pics but I don\'t seem to be able to post them, will see if I can upload em onto photobucket.
D2BBA
Thank\'eee kindly matey!
Will go and have a play with me nipples and see what happens...... :rollin
 :cheers again!
Chris
