atkins 3mm racing apex seals
Started by stuart wizy, February 05, 2006, 12:11:37 PM
stuart wizy
anyone used atkins 3mm seals?
just ordered 3mm tip overhaul kit with solid 3mm corner seals and all oil and water gaskets and o rings, all apex seal springs and side seal sprigs, corner seal springs    480 dollars!
asp
i did the same but with 2mm,every thing look\'d good quality,just gota run the engine in now, :D
stuart wizy
are them your bridge ports on pic?
get me a template! nice work if they are
asp
get me a template!  asking like that aint going to get you anything,,
i dont think carl would be to happy if i gave out templates of his port\'s,
sorry no can do,
stuart wizy
ive spoke to him today about the ports and he,s helping me out mate
he told me to check your ports out on the piture and they look top quality, really good job, have you run the engine yet?
asp
he did a very good job doin my ports,have run the car for about 2hour now,
took it out for a little drive today,it idels at 1500rpm,its very brab brab,
road tax time i think now :D  :D
Carl
Did you get it sorted Kriss?
Regards
Carl
asp
it was a bent fork arm,the bar that pushes on to the release arm i end\'d up putting a bar that was 5mm longer in there,no worries thou iv got a os giken clutch to in jus gota get a thrust bearing for it,
thanks for the help carl
