Twin turbo....twin Boost gauges?
Started by simonman, January 31, 2006, 01:45:35 AM
nikp
When i took my FD to pip to have a boost issue sorted out, he somehow sorted out my transition too - it\'s now smooth.....unless my second turbo has stopped working, but i still pull 0.8 up to the red line. And it was always smooth, even when running back frm pip sorting it out. I don\'t know what he did though - he said he could sort something out - but he didn\'t say what it was!
Martiny
If only we knew what that trick was !  Are you on the standard ECU nik?
nikp
QuoteAre you on the standard ECU nik?
I was at the time - I\'m not now.
I dunno - I\'m tempted to phone pip up at some point and ask him, as I seem to be the only person he\'s done this for!? Maybe I\'m imagining that he said it now? I\'m starting to doubt myself now!!
I\'m on an Apexi ECU, and thought i\'d try and figure out if the second tubby is working last night, so i disabled the sequential control. I presume that means it\'ll just run the frist turbo, but seeing as i was only in commuter ville at the time, wasn\'t able to get a decent run to identify anything. However, boost peaked higher than it ever did at 0.9 bar, rather than the 0.8 it usually runs, so i got confused and stopped!
