diagram of fd coolant path
Started by asp, January 17, 2006, 07:05:27 PM
asp
need to no where to pick up coolant feed and return for turbo.
cheers
Sorry no one got back to you,
 Both Turbo water hoses pointing back wards toward the bulk head, behind the thermostat housing down behind the rad cap on the engine and you will see two 10mm water hoses .
Also it does not mater which way these are plumbed onto a single turbo.
Hope this helps
asp
