Engine Rebuilds
Started by izhereal8, December 05, 2003, 10:14:42 PM
izhereal8
ONE OF THE KEY THINGS ABOUT MAZDA RX7\'S IS THE FACT THAT THEY ARE HEAT MONSTERS IF I WAS GOING TO DO A REBUILD I WOULD START OFF WITH CERAMIC COATED APEX\'S  THEY WILL LAST LONGER THAN JUST THE ORIGINALS ALSO ANOTHER KEY IS THE BREATHING AND THE EXHAUSTS SYSTEM. MAKE SURE THAT IF U ARE GETTING SOMEONE ELSE TO DO THE JOB THAT THEY USE NEW PARTS THAT THEY DON\'T MIX AND MATCH BECAUSE I HAD GOTTEN BURNED THAT WAY.  GOOD LUCK ON YOUR REBUILD   SINCERELY IZ......
