Fitting a boost gauge???
Started by tr1cky, November 15, 2005, 01:18:17 PM
tr1cky
Ok guys, need some help with fitting a boost gauge, never done it before, so sorry for any stupid questions! :confused:
Got a RE:Amemiya gauge \'n pod holder, steering wheel column mount. Gauge has two wires, one must be earth!? Guess the other is for light?? Can this be tapped into the cig lighter for power?? If not where to go??
Need vacuum pipe and I guess a \'T\' piece to feed boost to gauge- wheres the easiest place to get?? Do I need nything else?
When fitting this were do I need to tap into to take the boost reading?? (some pics would be fantastic for this! but good discription would do :D ). Also whats the best way through the bulk head into the cabin??
Thanks for any help!! :chat
Rich
The FC is dead, long live the FD
McCARTHY
any 12volt supply will be ok for the light, so yes ciggy lighter will be fine.
Other than take my boost quage is electronic so pluming a little differant to yours i think
As for the T peice and vaccume hose any local motor factor shouls have both aprts of halfords somewhere like that.
dre
There should be a black rubber plastic cover on the plenum (drivers side). Attach there.
DRE  :cool
Jodypamplin
Feed this pipe from the phlenum through one of the holes on the left side of the engine bay - there should be wires and all sorts there already. literally push onto the top of the phlenum. good luck  :cheers
the lemster
you can take the lpower for liught off from behind the dimmer switch on the dash... go in through the stereo din panel and on the right you will see a small box this kind of comes out backwards ( there is a catch to let it come out) just scotch clip it int tp there and the gauge will dim with the other lights...
the vacuum pipe should go through the front grommit with the bonnet release or throttle...
good luck
tr1cky
Have been lazy lately and not got round to fitting this :flamed
Struggling to find a \'T\' peice to spilt the boost hose with. Local Halfuards, DIY stores, etc have anything :Grrr
Where can I try next??
Eddie
Hi mate
Your best option instead of a t piece is to tap in the phlenum, on the oposite side of the throttle near the drivers side you should see a black rubber nipple take it of and put your pipe here, works for most people.
tr1cky
Quote from: EddieHi mate
Cheers mate, will give this ago later in the week! :WaveBye
