apexi avcr and power fc
Started by whinger, December 23, 2005, 07:36:02 PM
whinger
hi all
i have a avcr boost controller and i was wondering if it is possible to patch the standard wiring loom into the apexi avcr map sensor so it will supply both the avcr and the power fc and dump the the factory map sensor or will i get false readings.
i would prefer to keep the avcr functions if possible and though this would save me buying another map sensor.
regards
chris
chrno
I dont thinkt that it would be possible.. As the Std mapsensor is the exact same one that comes with the Apexi PowerFC D-Jetro (mapsensor version) to non Mapsensor cars.. If they wouldn\'t need that one.. the kit would only use the one from the avc-r..  The std one (or atleast the one for D-Jetro) is a 3ba mapsensor.. Dont know the spec on the other one.. I had 3 sensors on my silvia.. Bt was going to run just 2 for next season..  before this happened..  //www.coconut.se/akira/krock/
Best regards, Daniel
