Automatic and Triptronic??
Started by interloper393, December 21, 2005, 01:18:08 PM
interloper393
Cn anyone explain what the differance is please lol  :wave ]
Juriën
With tiptronic you have the option of shifting gears, so you\'re able to decide when you want to shift gears. With an automatic the system decides for you all the time.
There are different types of tiptronic systems. I\'ll leave that to someone with more in depth info.
Cheers,
Juri
                Follow your guts
davegttph1
I thought Tiptronic was a manual car and you change gears with buttons by the steering wheel rather than a gear stick????
probably wrong but could have sworn thats what it is.
Rich Cheung
Most of the FTO\'s have a Tiptronic gerbox.
In automatic mode you have your usual park, drive, reverse, etc choices then if you flick the gearstick over to the left you have +up -down options to change gear. No controls on the steering wheel though.
I was lucky enough to have a manual as the Tip box sapped quiet a bit of power over the manual box.
Rich   :)
Phasen sehnen sich das Hoff
長くHoff は住んでいる
interloper393
ahh cheers lol.. cant beat the good old stick :P
i thought triptronic was a up/down selector but without a clutch :/
Rich Cheung
Yeah theres no clutch in the Tiptronic FTO\'s.
IIRC I think when your in drive in the automatic mode you can then push the stick to the left and go into manual +up - down mode. The gaitor looks a bit like a staggered H. Hope that makes sense.
Rich  :Thumbs-up
長くHoff は住んでいる
antnicuk
inteloper, you are right, the steptronic is an up and down selector without a clutch, i have it in my BMW, some put the padels on the steering column and some use the gear stick when in drive you just push it left as mentioned above and click it up and down as you please,   even though i have only just bought my BMW, i have rarely used it as if you have enough power you might as well just floor it and let it kick down, i cant tell any difference in performance.  Although it is good for engine breaking as once its in gear you have the benefit of direct engine breaking.
