Tyre Buying Help/Advice?
Started by will2j, December 01, 2005, 05:54:04 PM
will2j
Hi Guys,
I am wanting to change the tyres that came on my imported rex for uk jobbies. The tyre sizes are:
Front 235/40/ZR18 & Rear 265/40/ZR18
Is anyone on here running the same size tyre? If so any advice on which brand and model I should get would be greatly appreciated.
Also when getting my wheels tracked and balanced, the guy as the garage was unsure as to what tyre pressures to use? I said 26 front and 30 rear, does that sound about right?
Any help/advice would be greatly appreciated.
Will
will2j
All sorted now!
Bridgestone Potenza S-03\'s. Went for 265/35/18 in the end as per the sticky post in this thread.
Only got them on the rear so far as The fronts are good for a few months yet.
First impressions are that there is alot more traction now, doesn\'t kick out as much as she was and the noise I had over 100 has gone!
More of an update I can really test them :3gears-rh
