Tyres
Started by mpk490p, October 20, 2005, 05:49:33 PM
mpk490p
Has anyone fitted a 225 tyre on the back of a series1?
looking to fit 225/40/16\'s on the back and 215/45/16\'s on the front
Christopher
I hear that 255/50/15 fit.
                    /60/
That what Iam butting on once my Turbo II calipars are on.
But not to shaw about 16\'s.
//www.Rx7club.com they have done anything and evrey thing, take a look.
Pete.
MikeLMR
on the back maybee ... but on the front ?! not with standard arches ?
I have 205/50R15\'s on the front of my series 3 and the clearance to the strut is less than a mm !
IIRC there is a load of room at the rear, but you would need to alter the offset of the rear wheels to suit (otherwise they will catch the outer)
mpk490p
ive been running 215/45/16 on the front for some time, i did take some metal off the front arch just incase but they run fine, i was just looking at the rears really as i\'d like a bit more rubber on the floor
MikeLMR
you must be running a lower offset than I am either that or narrower rims (15x7\'s all round on mine)
if you know the offset of your front wheels stick them on the rear and measure how much room you have then decide how much wider you can go with the wheels and adjust the offset to keep the outer rim in the same place and add the width on the inner.
mpk490p
i belive mine are 16x7 to be honest there was no sience behind it they just worked, i might of had spacers on them, ive not fitted the new alloys for some time so i cant remeber
