Pulling to right on acceleration.
Started by robedwards99, October 23, 2005, 07:53:42 PM
robedwards99
On the way home from Eastleigh this afternoon I noticed that the FD was pulling a little to the right on hard acceleration from 70mph, and if you lifted off suddenly the car would lurch to the left due to me counteracting the pull to the right.
Has or does any one else experience this?? or any suggestions what it might be??
I hope that all makes sense!! :)
Rob.
Carl
torque steer.
Check your tyre pressures are even in the back too.
Regards
Carl
cjr
i would hazard a guess that your rear bushes are fduked
A small turbo
ro284
HI Rob, I can tell you if the bushes are worn, i had mine done last week at Tims,let me know,
cheers Bob
Warthog
Sounds to me, if this has only just started, that your tyre pressures are out. ( As Carl said ) I had the same problem. I run 28psi front and 30psi rear. That may well give you a starting point. Alter until you are happy.HTH. :)
Project Evil seven.:evillaugh
Hi Rob,
If none of the above works think about looking at the rear shocks and then having a geometry check carried out as it could mean the tracking at the rear is out.
robedwards99
Thanks for the advice everyone.
As it\'s pouring with rain I think I will leave it for today before I attempt to research the problem any further.
My instant thought was torque steer but I thought it felt a little severe for that. I could be wrong though as this is the first RWD car I have owned and also the first car with this much power.
It may well be tyre pressures as I\'ve not checked for 4 weeks I will check and report back (when the weather has sorted itself out!!)
Thanks again.
Rob.
robedwards99
Just checked the tyre pressures.. 30 all round so I think I can rule that out.
Bob... you have a private message!
ro284
ro284
dandan
*ahem* i have some bushes and/or suspension for sale rob, what luck!
although of course i hope it is a cheap thing to fix, but if not, let me know!
PETE SMITH
Hi Rob,
Are all the tyres of the exact same tread pattern?
Different tread combi\'s can cause pulling to one side due to different surface grip times
It happened to me a few years ago
Pete
robedwards99
Thanks Dan, I will let you know.
@Pete... I\'ve just got back from ro284\'s (met with fro too!) and we realised that the tyres could be to blame. ATM they are all different patterns and differing tread depths.
I think my next step might be a new set of rubber on the corners.
Thanks for the advice :)
Rob.
Brett
I had a very similar situtation caused by worn shocks, they dont take long to change so its worth having a look :)
Brap Brap Brap Brap
