Butterfly flaps in upper inlet manifold - can i remove them??
Started by gavink, November 16, 2005, 01:36:54 PM
gavink
Hi...
Just doing some work on my rex - is it ok to remove the second set of butterfly flaps (actually in the upper intake manifold)?
Also my throttle body is leaking water (at the back where the coolant hose joins it),is it ok to bypass the throttle body and just attach the coolant hose to the pipe underneath? :)
gavin... :)
gavink
What did you use to blank off the hole thats left on the side of the UIM..Was just thinking about cutting some threads then screwing a bolt in (obviously cut to length)..??
asp
funny enough thats what i did,put some lock tight on it also, :)
FD3Typer2
FD3Typer2
The hole that\'s left when you remove the butterflies that is ;)
D3S
I have done it on mine, pretty easy to be honest gains are well not really noticable except seems a bit smoother on the acleration.
The bugger was the screws in the butterflys, i had to drill those out in the end.
Also the big hole left in the side of the UIM left from the shaft of the butterfly\'s i just plugged that with a bolt nearly the same size and exhaust instant gasket. did the job for me :)
Gav
asp
Quote from: D3Sgains are well not really noticable
Gav
as thay say at asda,every little helps
D3S
lol that is true, i have heard you notice it more when your pushing big power.
Gav
gavink
I thought now was the best time to do it as ive been doing a fair bit of work on it before i get it maped. :)
D3S
Its a good idea...i my method of madness is read what people do to mod their RX\'s on the cheap or to solve issues and just take it apart lol
Just hope it works when i put it back has so far hehe.
But with removing the 2nd butterflys, remember not to rev it passed 3k when cold, that is the reason they were there in the first place so you could open up the throttle when the car was not properly warmed up.
Gav
gavink
i never thrash it from cold anyway so thats not really an issue :)
