Intercoolers from another vehicle ...
Started by grinder, October 16, 2005, 08:14:04 PM
grinder
Hiya chaps
would this be OK for a rex ? : http://cgi.ebay.co.uk/mercedes-sprinter-VW-LG-van-intercooler_W0QQitemZ4582210025QQcategoryZ10398QQrdZ1QQcmdZViewItem
all i know that it cools air - but does fitting a larger one cause problems ?? is there a specific size you should look for , would a HUGE one have a reverse effect
Stu
The tightest man on earth
:Giggle
Jono FD3
From my understanding it should be OK, as long as the new IC can flow the amount of air your turbo/s are pushing out. if the intercoolers air flow rate is less than your turbos produce then it will actualy reduce the power out put of the vehicle!!
You\'d be better off looking at a Sunny GTiR IC and front mount that insted of the van one you have linked!
Jono
kev-yorks
Looks like its got plastic end tanks it will be OK for low boost but if you turn the boost up too much they have a habit of blowing the end tanks from the core as they are only clipped together.
Kevin
Regards Kevin
grinder
ok . cheers guys makes more sense now !
:Giggle
travellinbob
The seller has an interesting name? rx7gilbert.  does anyone know him?
