RX-7 3rd Gen (easy question) : at what revs does each turbo kick in?
Started by chrisBoid, August 26, 2003, 04:51:20 PM
chrisBoid
...assuming a standard set-up on a \'96 model.
Iwan
QuoteOriginally posted by mr_tim
IIRC 1st turbo 2500rpm then 2nd @ 4500rpm
generaly yes, but they are ranges where turbos kick in depends on ECU.
The first is running all the time. You have lag on it till about 2200 to 2500 RPM as mr_tim wrote.
The second one should kick in at about 4500 to 5000 RPM.
REgards
Iwan
still remember,
NO ROTOR, NO MOTOR !
gavin
should the power be smooth all the way between the first and second turbo or is there a brief loss of power??:wave :wave
J4P RX
gavin
wasnt sure if the car was running okay as it felt like a slight miss but must just be the switching of turbos, thats put my mind at rest,  :rollin :rollin :rollin
