fd3s head light problem
Started by zerocool, October 02, 2005, 04:36:18 PM
zerocool
hi, can any body help, my rx7 front lights have popped up but will not rotate back down when you turn the lights off.your help would be much appriciated thanks
RobbieRX-7
make sure the winter switch on the dash is not pressed in. This switch is used in the winter to pop up the lights to stop the freezing weather freezing them closed . The switch pops up the lights but does not turn them on. Its also used for when you come to clean the lamp lenses.The button is on the right hand side of the speedo.
