Main Menu
boost
Started by shortcircuit, October 01, 2005, 07:11:07 PM
shortcircuit
at last i have boost !!!! :yes collected my car from rotechniks today , turns out the problem was a blocked cat . kicking my own ass as i checked the intake side but not the exhaust  :spank but i guess every day\'s a school day. now it\'s time to turn up the blitz boost controler . what boost is safe before the fuel cut comes in ? thanks for your help :cheers
Brett
Well first off I\'d get and FCD, the knightsports on is going for around $50 on ebay.com at the moment.  I\'m running about 10psi max, I\'ve heard 12 is the maximum safe level, assuming every other part of the fueling and ignition system is working ok.
 Its worth checking all your vacuum/pressure lines first, any cracked pipes will start to split now your boosting.
 Out of interest, does your in car guage work ok?
Brap Brap Brap Brap
shortcircuit
Quote from: BrettOut of interest, does your in car guage work ok?
not to sure  :xconfused will check tomorrow on the way to the d1 comp.
MattR
OO..i envy you!!.. i still have no boost!! got my engine in bits.. getting there slowy!!!
Good luck with her mate
shortcircuit
thanks , hope yours comes together soon .
Brett
Shifting this into the general technical section.
Brap Brap Brap Brap
