Exedy Twin Plate Clutch problem
Started by DreXeL, September 18, 2005, 04:11:01 PM
DreXeL
I have just got my JDM \'92 Type-R FD up and running after rebuilding the engine.
When I went to drive it the clutch pedal just went straight to the deck, I then lifted it by hand and pushed it again and it firmed up, carried on pushing it and got a terrible grinding noise and vibration through the pedal.
So I jacked the car up and had the wife push the pedal whilst I looked through the lower service hole, and the fork was traveling right back into the pressure plate cover. The fork isn\'t bent or broken. Looking through the hole in the side of the pressure plate cover I can see that the pressure plate isn\'t engaging against the clutch plates, the clutch is stuck \'open\', which means the diaphragm is pushing against the fork, so when the clutch pedal is released the fork is only about 10mm from the clutch cover. It\'s because of this that when I push the clutch pedal it pushes the fork into the cover.
Why is the pressure plate stuck like that, and can it be fixed without pulling the gearbox?
I have come across this same problem.
The release bearing "snaps" onto the pressure plate via a snap ring and this means that it has unclipped it\'s self.
Unfortunately you will need to remove the gear box to put it back together and find out why its become unclipped.
p.s. don\'t try and drive it any more as the slave cylinder push rod has probably  fallen into the bell housing by now
