Do you have to replace metal gaskits
Started by RobbieRX-7, September 05, 2005, 09:25:41 AM
RobbieRX-7
as above, i did the rats nest a while ago, but suspect a faulty check valve so il need to take the uim off again, question is that although i replaced the old paper gaskits with metal ones when i last ripped it all apart, do i need to change the metal ones again, or could i get away with using some blue hylomar.cheers lads!
nikp
Strictly speaking you should replace metal gaskets once they\'ve been used, but you can get away with not replacing them.
