Clutch Problems
Started by Jame5, August 19, 2005, 05:15:00 PM
Jame5
Approaching a roundabout, tried to engage 2nd gear. Push the clutch in, couldn\'t get it into gear. So I turned the engine off, engaged 1st gear, drove home using clutchless gear changes. Managed to make a few notchy gear changes. Got the car on the drive. Can\'t engage any gear even when pumping the clutch lots. When the engine is running and I push the clutch it I get a grinding sound from the clutch. Is this a clutch problem or sounds like air in the system?
sadgoth
sounds like your clutch has gone walkabout mate! I hope I\'m wrong and it is an easy fix, but those are the symptoms I had with an old 205 I had when the clutch died.
Mark
89 Black FC3S Turbo II
Loud? Hell yes! :D
asp
if u can get it down my yard 2mrw il hav a look 4 u, :D
K1HKS arse
its gonna be clutch pack,release bearing or common fault-clutch fork broken. Have you still got a good pedal feel????????
As Gary says, its probably a broken fork, whatever its internal so unfortunatly your going to need to pull the box out  :(
Jame5
The clutch feels pretty soft when u start to push the pedal down. When you get nearer the floor it gets pretty heavy. I was just about to book it in for PFC too so I doubt i\'ll be doing that now until the clutch has been run in. :rolleyes:
venomturbine
my clutch make some problems too
enouth rmp but no speed (in german: das scheißding rutscht durch)
ok i need a new clutch but i spend my last money for one week amsterdam
my question:
is it possilbe to reajuste my clutch
i know thats possible by some "older" cars
but what about my rx?
thx for help
Mazdarotaryparts
Quote from: venomturbinemy clutch make some problems too
my question:
thx for help
If it is a 2nd or 3rd Gen then you can increase pedal freeplay under the pedal on adjustable rod that goes into the master cylinder.
 unfortunately you only really use this to set up the clutch on installation.
Once these clutches slip that\'s your lot, sorry.
BTW To give you an idea of cost we sell standard 3 piece 3rd Gen clutches for £300 +vat
REgards
Clive
Mazdarotaryparts
Racingbeateurope
Racecarbattery
shyauto
g11ary
Hi James
Same simptons was I had, turned out to be Slave cylinder had not been put on properly, Geff had only put one bolt loosely in the slave, so that by the time I had drive home from him, the slave was moving instead of pushing the clutch, so hopefuylly a simple fix of tightrning or put bolts in, the only other time something similar to this happened, the folk that operates the clutch had snapped. Id put money on one of them 2.
Jame5
The clutch arm was knackered in the end but the clutch looks pretty worn so I\'m replacing the lot. I\'ve got no intentions of going for single turbo or high power so I\'ve decided to go for a stock kit. Mazda wanted £356 inc VAT for a clutch kit including the release baring. I ordered one from Rotary Art for £290 inc. The clutch fork is coming from mazda though for 55 + VAT. Nevermind  :rolleyes:
asp
so shes gona be back on the road soon then,
just as iv taken mine off 2,oh well,
Jame5
Hope so mate. I\'ve ordered the power FC from Japan so that\'ll be turning up the next few weeks. Fancy mapping it for me?!?  :3gears-lh  :yes
What is the engine looking like at the moment? I wouldn\'t mind coming down to have a look at the thing in bits.
asp
map it 4 u,lol,
i can c it now,yea asp had a go n popped it,sorry mate,
engine is all apart now,u can pop down for a nose if u like,
