check valves
Started by Madden, August 13, 2005, 06:30:24 AM
Madden
Hello
I have been have problems with my fd since i took the double throttle butterflys out.  Found out the problem the check valves have stoped working not letting any vacume through anyway what so ever.   My question is do i need to use the one way valves or can i just leave them out?   Also where could i get a couple of them from?  Do the mazda dealers normally keep them in stock? and how much?
Chears Jamie
FD3Typer2
You DEFINITELY need the check valves.
Dealers will probably expensive (but new)
I bought some last year second hand from Jimmy\'s for £15 each.
For my current car I got mine from Dale Clark on rx7club.com. Delivery was lightning quick. $25 shipped for 4 valves.
See here to order
 http://www.clubrx.org/default.asp?id=8&ACT=5&content=26&mnu=8,
As the advert says, they are a little loose, so you should probably use 3.mm hose for the lines with valves in them.
These are pretty heavy duty though! http://www.rx7club.com/showthread.php?t=164819&highlight=viton+check
Madden
Just recieved my new check valves form mazda and they are very very heavy duty and made out of stanless steel.  So thats why they cost £23
FD3Typer2
I have never seen the stainless steel check valves. Would you mind posting a pic?
Madden
cant post but i can email it to you
Jamie
