Wont start when hot
Started by scud, August 16, 2005, 01:04:21 AM
scud
What does it acually mean when a rx7 wont start when the engines hot.
Im looking at a car but the ad says " the car will start normal,run normal but it wont restart off the key when the engine is hot.
Is this a big problem ?
Scud
Brett
Could be leaking injectors or poor compression, or both.
Brap Brap Brap Brap
grinder
its a big enough problem to walk away from it - unless its super cheap
The tightest man on earth
:Giggle
Warthog
It\'s a rebuild job. Just had my engine done, it had the same problem. Side seals etc had gone. Don\'t buy it unless it\'s dirt cheap.HTH. :wave
Project Evil seven.:evillaugh
iaint
Quote from: scudWhat does it acually mean when a rx7 wont start when the engines hot.
Scud
It is, as posted, almost certainly the sign of a very tired engine.  Basically, the compression is low (i.e. the seals and housings are badly worn).  When cold the oil is more viscous (less runny) than when hot and therefore has compression when cold but not when hot.
Once the engine is running it generally keeps going because (i think) the gyroscopic forces help the rotor tips make a decent seal.
Walk away if it\'s above 4k.  The rebuild will be a minimum of 3k realistically and likely to be in the 3-4k region.  Car after will be worth (if standard) up to 8-8.5k.  Do your sums and take your choice!
Iain
scud
Thanks for advice guys, gotta give it to ya you lot know your stuff.
Scud
Carl
once the engine is running the gas pressure from combustion helps to make a good seal by getting behind them and forcing them to do so.
When the engine is hot the seals and springs that are tired and worn don\'t give such a good seal due to everything expanding and bigger clearances opening up.
So the engine does as everyone has said in all likelyhood need a rebuild.
Regards
Carl
