Will Skyline R34 GTR fuel pump work for FC?
Started by samfc3s, January 07, 2006, 02:52:17 PM
samfc3s
if so do i need to modify or they are not compatible? thanks in advance!
Sam
Panspeed tuned FC3S.......
samfc3s
i just want to know if they are just drop in fit or need to modify???thanks
Iwan
not sure about this so far, but if you send me one, I will try it for you :)
REagrds
Iwan
still remember,
NO ROTOR, NO MOTOR !
samfc3s
i m quite sure it will work but just need some modifications
thanks for ur offer tho ;)
cjr
It will work. You just need to cut the feed pipe a bit and fit the sock onto the end off the pump.
A small turbo
