3500 revs at start up???
Started by R32 Nik, August 06, 2005, 09:44:17 AM
R32 Nik
Just wondering why Sarahs TII starts at approx 3500 revs until she dabs the throttle and then it drops to a normal "on choke" idle speed.
Is this normal or is there something that anyone can suggest as to why it is doing it.
Nik
peterch
sounds the same as my third gen. Try starting it  with your\'e feet on the clutch and brake pedal when you turn the key. That seems to make a differance in mine.
R32 Nik
Thanks Peter, I\'ll tell her to give it a go.
FD3SNuttah
yeh mine does that from cold starts at 3000 revs and then sticks there for alittle while and then it goes to 1000 revs so thats normal, if you dab the pedal it stays at 1500 revs for longer,
so you got two options wait for a minute at 3000 revs or more time at 1500.
TRex
The correct answer is,,, the cars have a cold start feature... on inital start up they will rev to 3 - 3.5 for I believe 20 sec and then come down to 1.5 and as the temp stablizes it gets normal idle.
 rgds
FD3SNuttah
yeh thats nearly what i said... see im learning!
t2rew
it says in the hand book that it does it for about 15 seconds. personally i start it in gear and once it fires i lift the pedal to drop the revs. i belive its to try to stop the rotary tendancy to flood and also get the cats hotter quicker to alow them to work.
R32 Nik
Thats OK then. As long as it\'s normal it\'s not a problem. Sarah was just worrying about it incase it was something going wrong.
Thanks all for your info.
Nik
Brett
Yeah, in the hand book it mentions this as a \'starting aid\', you can either blip the throttle slightly or let it come down of its own accord.
Brap Brap Brap Brap
