worn bushes.... which ones...
Started by the lemster, August 01, 2005, 01:27:11 PM
the lemster
nice one...
am doing an oil change at the same time so have the car on stands allready...
just hope I dont shear any bolts off... will be well soaked with penetrating oil before I try turning and  if I cant manage it I will leave it as i off to santa pod in the morning...
woohohooo
cheers for the help
the lemster
Quote from: TURBOIINUTTAHyou will need to jack the A arm up when you take the links off, as the roll bar will spring upwards! it was a bit of a fiddle on the 323 the suspension is nearly the same thing here, make sure you support the car well mate, you\'ll need axel stands and a decent trolley jack. you can get these for not much at your local parts store.
good luck with it mate, u can save yourself a tidy amount doing it yourself!
I assume that I just take the weight off the wheel so it dont hang down... hmm best way to do that?... can I jack the wheel up....best jacking point is?.......
