FC3S Modifications and results
Started by Brett, April 12, 2005, 11:16:00 AM
Brett
You need to do it when you are building the engine! :yes
Brap Brap Brap Brap
Matts-gen2
oh, i see.
nevermind then.
:3gears-rh
billybobbooth
Quote from: Matts-gen2baffles from exhaust port? how do u remove these?
where are you talking about exactly, ive had the thermal reactor removed, is this what you mean?
where does your cold air feed come up from, it theis with a K & N cone filter?
my air intake has been re-built from the start of the air pipes to the air filter,
i have the afm right next to the tb\'s with a hard pipe to the custom carbon air filter then cold air feed from behind the cold side of the rad, the fan helps to cool the air going into the air filter too, and the rad protects the air feed from big bits of durt and from rain and flood water from getting in if i go threw a ford or something!
i was told my baffles were done after the engine was put back in by the last owner
Matts-gen2
sounds like its got the best cold feed it can have, got any pics?
billybobbooth
i dont know how to put pics up on here but if anyone can do it for me ill e-mail the pics to you,
dthebuk
Quote from: Matts-gen2sounds like its got the best cold feed it can have, got any pics?
my car now, there some pics http://www.mazdarotaryclub.com/forums/showthread.php?t=47375
:burnout
Brett
Brap Brap Brap Brap
Brett
This thread will now be closed.
Please see here for details of it\'s new home and format.
Brap Brap Brap Brap
