car failed mot on emmissions
Started by neil97rs, August 02, 2005, 06:39:59 PM
neil97rs
help its that time of year m.o.t needed running co level at 2.93 before machine aborted 3 times ,should be .30 .car is a 1997 type rs engine rebuilt 6000 ago only mod is exhaust been in the garage since friday can,t find anything wrong any ideas :
goose
Find a *cough* special *cough* MoT station.
Or try an Italian tune-up (assuming your cat isn\'t toast of course).
babz_audio
mine ran at 8.9  :chat  but i found a special garage who sorted it out some how, some real clever mechanics  :rollin
RE:Amemiya RX7 R2 Single Turbo HKS T04R
e-mail: mo9797uk@yahoo.co.uk
neil97rs
:burnout im afraid my job will not allow me to find a special garage being one of those people who drive around in silly diesel cars with stripes on the side and silly blue lights on the top u know the ones good idea though if i could get away with it
Brett
Depending on what you have to available for adjustment under the bonnet you may be able to gain a bit.  Best soloution is to put the CAT back on for the MOT, unless you want to start fabricating your own air bypass system into the UIM at idle? (Which I did on my old FC, worked a treat, but then that was an \'88 car so had more leeway with the regs any how.)
Brap Brap Brap Brap
peterch
don\'t you get better results if the engine revs are belowe 3,000 rpm for the test, ie, so that the air pump is still running.
Wav
Talk to Brian Ellis (Rotary Imports), I\'m pretty sure he\'ll be able to sort out your car "legally" in order to pass:).
Good luck with it,
Paul
RX-HEAVEN.COM
Hi Neil, I am sure that we would be able to help you get your M.O.T. We do not test ourselves, but have a test station next door. however we do have the ability to test to MOT standards inhouse, & have a great deal of experience in such tasks. We are not too far away from you as we are in Horsham.
If we can help, then ring 01403 734666 (RX-HEAVEN Ltd)
Carl
Or take your car to Thames Valley MOT\'s in Reading.
The owner Dave Thompson has got a heavily modded FD RX7,it is running a single turbo with very free exhaust.I think you get the picture.
His number is 01189 560044
Tell him that Carl sent you.
Regards
Carl
