advise required, Alternater pulley removal (air pump)
Started by Eddie, June 30, 2005, 10:40:25 PM
Eddie
Hi back again for more advise:)
can anyone tell me how I would remove the bolt on the alternater, I have a greedy set of pulleys which allows the removal of the air pump, but cant budge as it spins:)
I am sure its simple just need to know what tool is needed.
Should have taken it to WGT but I just like having a go at things.
Also I have removed the air pump, the car had the cat removed by pip when I first got it.
Apart from unpluging the power and blocking the big tube do I need to do anything else.
I am fitting a apexi ECU whilst I am at it so this I believe should sort out any ideling problems form removing the pump? or I am totally wrong.
Any help apreciated.
DRAGON
You need a compressor to get it off, if you dont have one, just take your alternator to any garage and ask them, they should do it for free.
Eddie
Hi
Thanks for that I thought so, bloody thing kept turning as I tried to take it of.
