Turbo Timer
Started by Kieron, June 07, 2005, 10:05:35 AM
Kieron
I\'ve just brought a turbo timer off e-bay that can also read boost pressure and desplays it on an LCD screen. Not bad for £6.26 :p
It comes with a harness but afaik it wasn\'t on an RX7 before so I will need the correct harness for this. Does anyone know where I can get one from? If not, how hard would it to be to get this to work, cut and solder job.
Thanks for reading.
Kieron
Adam
Depends on the brand mate...eg HKS  BLITZ Greddy ????
Adam
Kieron
DOH!!! its an ULTRA turbo timer.
AFAIK it goes:
RED = Perminant live onSwitch
BLACK = Ground
BLUE = ACC on
GREEN = Main ignition live on switch
Please correct me if I\'m wrong and please contact me if you could supply a harness for this so I dont have to cut up my ignition wires.
Tintin
I\'ve got an old Ultra turbo timer thats got a harness , doesn\'t quite sound the same as yours but it may do the job
Your welcome to it if it helps ( as long as next time I line up aainst you on the strip you don\'t make my diff go pop :rollin )
12.8@110.64 at RS4:Thumbs-up
Ada7
How easy are these things to fit and set up?
Have seen them on ebay at really cheap prices but been worried that you have to start dismantling the dash to get them sorted.
I AM HERCULESIAN
Kieron
QuoteOriginally posted by Tintin
Yeah plaese mate! great help, saves me cutting up my loom. Did you get your car sorted?
Adam, if it comes with an RX7 loom then itll just plug in!
