Boost controller
Started by A7NTY, July 15, 2003, 02:48:56 PM
A7NTY
Yes it\'s question time again for me.
I have bought an Apexi AVC-R for my RX7 and will fit once it arrives, however what I am unsure about is how it will work on the RX7 seeing as it has sequential turbos, do you just change 1 setting to adjust the pressure on both turbo\'s? I guess this is the case or do you have an adjustment for each turbo.
What are stock turbos good for anyway 1 bar boost? :confused:
Cheers, Anthony.
J4P RX
I cant be too specific, but Abbey fitted my EVC 5 into mine and it controlled the boost well.  No idea how they wired it up though.
I was going to run 1bar, but couldnt get any higher than 0.8 before I had fuel cut.  I think I remember your car has a Power FC though so you might be able to sort it.
Lee
