Anyone Recommend A Decent Aftermarket Clutch
Started by Icesurf3r, May 13, 2005, 07:03:43 PM
Icesurf3r
Ok guys on a follow up to my clutch problem earlier in the week, have had the rex checked out and the release bearing has totally collapsed and had knackered the rest of the clutch.
So i am after a complete clutch assemby for  my RX. It\'s running a T88 single turbo at just under 1 bar of boost producing 380 RWHP
Does anyone have a suggestion as to what type of clutch i should go for???  Any recommendations are welcome as desperately trying to get it sorted for Rotorstock.
Budget is a little limited so will be looking of a maximum of around £600 in total.
any ideas are appreciated
(getting rather desperate)
Scott
ScuttleRX
Might be worth just ringing round the main rotary guys, seeing what they\'ve got in stock, then go from there. I got an exedy clutch last year which was out of stock when I ordered it and it took absolutely ages to arrive, not what you want with rotorstock so close :)
In a nutshell if times a factor, i\'d see whats about before getting your heart set on one.
Hope your planning on going up the strip if you get all sorted, be nice to see a T88 fly up there
