speed limiter
Started by tonyafrica, May 08, 2005, 09:49:53 AM
tonyafrica
Hi everybody
I would like to know if someone can tell me how to cut the speed limiter signal to the ecu.
I do not want to go the chip route as we use kilometers down here.
I have done several searches but came up empty.
On my mitsubishi gto I just snipped a wire at the ecu.I hope maza have a similar fix
thanks
tony
shaunwil
Hi, I cut mine in the middle of fitting a delimiter and found the limiter was faulty. The new one didn\'t have one so i left the wire cut. The main problem is the speedo is wildly out at any reasonable speed. Ended up putting the wire back in for the pfc to get a speedo reading on the commander. I think it works very much the same as the pfc where it pushes the limiter upto 180mph instead of 180kmph.
Shaun
shaunwil
oops, works the same as the fto delimiter :rolleyes:
Shaun
tonyafrica
Hi
When you cut yours do you remember the pin number on the ecu or perhaps the wire colour?
tony
shaunwil
TBH i wouldn\'t reconmend it, on a private road i was doing 95 and the speedo said 120 ! messes alot with the car. Couldn\'t really say if it worked, never really got past that point before i put it back together !
Would have thought the japs would make something to do the job since they are still in kmph !
Shaun
