so where is the intake air temp sensor
Started by gavink, April 24, 2005, 08:13:59 AM
gavink
As topic really,ive had a good look but i cant find the bloody thing !! HELP !!! :)
gavin..
kev-yorks
Hi on a 20b its on the underside of the ali bend before the throttle body, i would think its in a similar area on the 13b. The sensor is only about 1/3 the size of a normal temp sensor with a 2 pin plug to it.
Regards Kevin
Regards Kevin
framey
Don\'t know myself, but maybe this diagram will help (Item #2)
Mazdarotaryparts
Hi Gavin
Yes it\'s the the same on your engine, look for a  small sensor thats upsidedown with a blue plug on it.
REgards
Clive
Mazdarotaryparts
Racingbeateurope
Racecarbattery
shyauto
gavink
Thanks guys just found it  :) , what a place to put it !!
Any idea where i can get an air temp gauge so i can put just after my I/C to see exactly what temps im getting..Ive looked up halfords for temp gauges(just basic thermometers with an LCD display) but i need one with a quick refresh rate..
gavin..
gavink
QuoteOriginally posted by framey
framey dont suppose you have the full list of what all those sensors are do you...i could print it off and that would come in very handy :)
gavin...
FD3UK
Hi I got mine from here   http://www.spa-uk.co.uk/design/dualgauges.asp    Not cheap, but very good gauges, you can set the built in LED to warn you if the temp/pressure goes above a preset level. Plus you get two lots of information in one gauge.
To use one to measure inlet air temp you will have to buy the optional thermocouple kit. I have mine installed in the elbow before throttle body. It reacts very quickly, which is more usefull than the information you get from the Mazda one via the PFC commander.
Kev,
framey
Here is most of the page. You can download the whole manual but it may take a while I seem to recall it\'s pretty big.
http://www.iluvmyrx7.com/
