Urgent Help Needed!!!
Started by fc3sPAT, March 28, 2005, 09:16:00 PM
fc3sPAT
what are the dangers of running the car on 3 spark plugs? the top plug (i believe is the leading plug) on the rear rotor is buggered!!!! it has snapped, dont ask how!!! :reallymad  and it rest of it wont even budge spent so long trying to unscrew it out just now and wont move at all!! and any bright ideas guys as to how i can sort this out????  quick replies please guys!!! thanks!!
Patrick,
Hi Patrick,
Real sorry to hear of your woes:( :(
Is it just the Porcelain top part that has broken or has it broken and  left just the thread in ??????
fc3sPAT
hi clive, the porcelain part has broken and the pin that the porcelain covers has snapped off too, there fore i am left with the nut and thread in place, if you can picture what i mean, basically i can get a socket onto it, but it is so tight it will hardly budge!!
so the porcelain and the bit it covers has come off!!! :eek:
any ideas as to what the damage it may cause to the engine running it like this? as i am in oxford right now and need to get back to work in london wednesday morning!!! :eek: :eek: :eek:
Carl
The plug it self won\'t cause a problem.
It sounds like the trailing plug from your description.
The engine can run only on a leading plug with no real probs,but get it looked at asap.Be careful of what you do with the high tension plug lead,the coil will want to spark to somewhere,if you can re-attach it on the plug that is damaged that would be best.Regards
Carl
fc3sPAT
thanks for the replies, thanks carl, so the top plug is the trailing plug right?? and driving with JUST the leading plug is not a problem right?? i just need a bit of reassurance, as am very paranoid right now as you would be!! :eek:
so stick the plug lead somewhere safe, and leave the plug stuck in there until i can get someone to have a look at it asap right??
cheers, anymore advice from anyone would be great!! cheers!!!
Patrick,
Brett
Run the car up at idle for 10mins to warm everything up.  Then have a go at removing the remains of the spark plug.
Brap Brap Brap Brap
fc3sPAT
will try that tomorrow, thanks brett, but failng that i will roll it to a local garage to see what they make of it too!!
Try what Brett said and just use even pressure and don\'t be tempted to yank it undone or it will snap.
Plugs in these engines bite up frighteningly tight at time but always seem to come out, eventually !
fc3sPAT
thanks for the replies guys!! its all been done now, the problem was that the threads had crossed which is why it wasnt budging!! so i ended up taking it to a local garage to take it out for me, anyhow, thanks all for the replies!!
Patrick,
