Blue smoke?
Started by Tim Oldland, March 16, 2005, 09:12:23 AM
Tim Oldland
Is it normal for the RX7 to give out a little puff of blue smoke on startup?
It doesn\'t happen all the time, only after its been left for a couple of days....
I\'m new to the rotary, so i need to know these things!
Cheers,
Tim
"Life moves pretty fast. If you don\'t stop and look around once in a while, you could miss it...."
        - Ferris Bueller, 1986
iaint
Hi Tim,
This is normal - the rotary uses oil (as you\'ve probably noticed) injected into the combustion chamber (provides compression and lubrication).  This is a small amount and is burnt off in normal running.  At startup there is a little extra in there to burn off so it smokes for a short while.
MillSpeed
Yeah, completely normal as far as I know. I wouldn\'t be surprised if the oil injectors seep a bit into the rotor chambers when the motor is shut off. You should\'ve seen the sh*t that came out of my exhaust after 10 months of storage!
Tim Oldland
Cheers guys, that\'s put my mind at ease.
Oh, and Iain, i\'ve got a shiny new 12x3" plate on the front now, it looks way better....
iaint
QuoteOriginally posted by Tim Oldland
Should have a higher vmax now then without the old \'air brake\' on ;)
