Pivot Headlight Controller
Started by jetpilot, February 27, 2005, 05:22:42 PM
jetpilot
Hey guys.
I have justed fitted one of these to my car. Am i right in that each time you make an adjustment you have to operate the pop up switch for it to work (turning it on and off), i.e you cannot just adjust it and the lights move up or down.:confused:
Gerry M
Operation & install manual, I still have one for sale if anyones interested.
http://www.pivotusa.com/installationman/pivrhu_m_t.pdf
The tartiest rx in scotland
jetpilot
Thanks Gerry, much appreciated. Still can work out if you adjust with switching the over ride button.
Tintin
To adjust the hight of the lights you alter the dial then pop up the lights and close them ( either by turning them on and off , flashing them or using the retractor button ) thing you will learn is that if you leave the dial set at say 50% your lights will remain half open , but if you turn the lights on again when you swith them off the lights will rest at 75% , so you need to zero the dial , you\'ll see what I mean
12.8@110.64 at RS4:Thumbs-up
