Single Turbo FC Engine Bay Shots
Started by chrisBoid, February 13, 2005, 07:14:08 PM
chrisBoid
Courtesy of Marty.
Marty, feel free to post some tech specs of this setup.
Enjoy :)
chrisBoid
AVENGE
Thanks Chris
The engine is from a s6 rx-7. The intake manifold uses the factory lower half with a custom top half. It has large bellmouths and a 65mm throttle body. It uses 4 x 1800cc injectors controled by a MoTeC M4 ECU. The turbo is a Garret ta45 which is really just a cheap truck turbo, but certainly does the job.
Internally its all standard Mazda, even the apex seals are stock. It has been mild ported and thats about it. The engine is 4 years old and has been in 3 cars.
Power and performance wise.
In the rx-7 on avgas it made 520rwhp but i never raced it. A friend wanted the car so i removed the motor and sold it.
In the rx-4 its now in it has run 9.7 at 138mp/h. The car is auto and uses the standard diff, it runs on 15 x 8 slicks.
Glenn Butcher
hehehe - who would ever use a MoTeC!  they\'re rubbish Marty!  :rollin
.ps Good to see you on here matey!
Thanks,
