T78 Fit
Started by FD3UK, January 28, 2005, 09:40:16 AM
FD3UK
I have removed my twin turbo setup plus all the redundant pipes, solenoids etc. The T78 is in on trial fit, all looks good apart from coolant feed pipe to heater. This is to close for my liking. I was thinking of removing this and using the supply that used to go to the throttle body to feed the heater? I have not checked this for correct flow direction yet.
I was hoping for some feedback as I know some of you guys out there have the same turbo.
FD3UK
overall view
asp
#2
asp
if u look at the pipe on thr throttle body is smaller,mite not let enuff hot water throu it 4 the heater..i took the pipe off that ur on about,i ran samco pipe round the front of the engine and done away with the metle pipe at the back,is that what u where after
asp
#4
hmmmmmwhat happed there,
can some 1 deleat this and my double post please
petemillis
Click "edit" on your posts and you will get the option to delete them yourself.
asp
iv tryd that,all i get is You do not have permission to access this page,
DRAGON
We cut the metal coolant hose, around the servo area and then extend the rubber hose to loop it in a more appropriate way. remeber to heat prooof it though, to protect it from the exhaust side of the turbo.
Also when we do single installs, we lose the throttle body coolant line all together, and just run the hose fromthe back of the rear endplate straight to the thermostat housing.
FD3UK
Ok I had also had thoughts on cutting the metal pipe in the same area, then routing a rubber hose in the same maner you discribed.
With regards to throttle body coolant supply pipe, If not used to supply heater I was just going to plug the pipe that exits rear plate and the return at thermostat housing. Is there a reason for not doing this and using a connecting hose, or this just your preference.
FD3UK
My polished snail has returned...
Dan Norton
Wicked......cant wait to get mine done now!!
Dan!!
Turned into the worst part of my life....my precious fd3 has gone, but never forgotten....roll on a new life!!!!
asp
very nice,who does the polishin and how much do thay charge,
mite have some ov that,
