can you help?
Started by davehg, January 28, 2005, 03:17:11 PM
davehg
ive nearly finished stripping my car ready for the spray shop but a couple of things have beten me so far,
1) how do oyu remove that pesky arial that goes through the rear wing??
2) i have a veilside spoiler, ive remove the two bolts at either end and it still wont come off.. am i missing something????
20B_boy
QuoteOriginally posted by davehg
Unscrew the retainer ring on the outside.
Remove boot trim that side and theres from recollection a couple of 10mm nuts or bolts. Helps if u have small hands and a widdly ratchet :)
R.
davehg
thanks mate boot is completely stripped now, i just cant turn the retianing ring on the outside, its the one with the two small holes in the top isnt it?
allstaruk
Yep thats the one, it can be a bit fiddly but mine went using the tips of a pair of needle nose pliers.
