Headlamps motoring
Started by mrfitz, June 16, 2003, 11:09:37 PM
mrfitz
Just picked up my 1992 car from the docks and the headlamps don\'t motor up??  Is it as easy as a fuse?  Been looking for a fuse map for ages but can\'t find one anywhere?
Any suggestions people?
Thanks in advance,
Mark.
There is a fuse block vertically to the right of the throttle pedal , not 100% sure but your blown fuse could be in there .
Hope this helps.
clive@mazdarotaryclub.com
//www.mazdarotaryclub.com
MikeLMR
Theres also a fuse board under the bonnet and on earlier generations there was a seperate box for the large rating fuses close to the battery.
mrfitz
Thanks for that guys, I\'ll go and check the fuses now....
Wait one....
mrfitz
Well, all the fuses are ok, even the 2 I dropped into the yonder.... bit fiddly down there!
Any other suggestions guys?
Do they have 1 motor each or both work off the same one?
Thanks again,
Mark.
