Rebuild Questions part numbers etc
Started by Shaq, January 20, 2005, 07:06:26 PM
Shaq
Hi,
I need to get my car rebuild but does anyone know the mazda part numbers for the full rebuild kit ? what bit s do I need I have attached a list of the bits I think I need is this correct?
- anyone know the part numbers for the 93-95 13b rotor housings ?
 here is a list is this all correct ?
Engine Gasket Set 8DF6-10-271 (1)
Front Main Seal 0820-10-605 (1)
Rear Main Seal 1668-10-556A (1)
Oil Seal Set 8871-23-180 (4)
Inner O-ring 0820-11-341 (4)
Outer O-ring 8341-11-343 (4)
Front Inner Spring N225-11-351 (2)
Front Outer Spring 1011-11-3553A (2)
Rear Inner Spring N225-11-361 (2)
Rear Outer Spring 1011-11-363A (2)
Apex Seal N351-11-C00C (6)
Inner Apex Spring N326-11-C04A (6)
Outer Apex Spring N326-11-C06C (6)
Corner Seal N326-11-C20A (12)
Corner Seal Spring NF01-11-C24 (12)
Side Seal N326-11-C17 (12)
Side Seal Spring N3Y1-11-C11 (12)
Rotor Bearing 1011-11-111 (2)
Pilot Bearing N326-11-D03 (1)
Pilot brg seal 1881-11-404A (1)
thanks
shaQ
Spotlamp
Hey Shaq,
In short I haven\'t got a clue, however I would suggets checking this site out in the US, you can order the complete kit and it\'s likely to be much cheaper than direct from Mazda.  The guy who sells the stuff comes recommended too.
HTH
H
RotaryResources.com
FD3Typer2
Hi,
I have used buce turrentine\'s kit and it had everything you will need to do the rebuild properly. its rotaryaviation.com.
I also have the Remove & replace, and 13b Overhaul videos which I have converted to DVD. VERY useful.
