Can you determine manufacturer age from....
Started by JVS RX7s, January 18, 2005, 03:26:22 PM
JVS RX7s
...........the chassis number on a FD3S?
When exactly were the RB edition cars started in 95?
Thanks in advance people.
sadgoth
found this which may help, but it is off a US site:
 A typical RX-7 VIN looks like:  JM1FD3311P0200001
    In order, the fields are as follows:
    "JM1"    "World Manufacturer Identifier" for Mazda
    "FD"     RX-7 series
    "33"     body style          ("33" = coupe)
    "1"      "Misc ID field"     (1993: "1" = US, "2" = Canada.)
                                 (1994: "3" = manual seat belts, 2 airbags)
                                 (1995: "3" = manual seat belts, 2 airbags)
    "1"      "Check Digit"       (used to verify that a VIN is not bogus)
                                 (calculated for each car)
    "P"      year model code     (1993 = "P")
                                 (1994 = "R")
                                 (1995 = "S")
                                 (Q was not used)
    "0"      assembly plant code ("0" = Hiroshima)
    "200001" serial number       (1993: started with 200001)
                                 (1994: started with 300001)
                                 (1995: started with 400001)
Mark
89 Black FC3S Turbo II
Loud? Hell yes! :D
iaint
Isn\'t that just the US car chassis/VIN numbers?  Mine follows completely different pattern as do all the others I\'ve seen in the UK...
e.g. FD3S107xxxx
sadgoth
they must have a similar system for the JDM cars, just trying to find it that\'s the pig!
Mark
Loud? Hell yes! :D
JVS RX7s
Sorry, should have said its for a JDM car
JVS RX7s
Ok, i understand the Rz\'s started 93/10, in a limited number so therefore 95 RZ is likeley to be a early 95 as they were coming to the end of the run.... no?
andrewrx7
Only roughly:
92-96 FD3s 100000 - 300000
96-98 FD3s 400000
99-00 FD3s 500000
01-02 FD3s 600000
I asked this on one of the Americal sites last year, and was told, that apart from the initial number (1-6 depicting the revision), the rest is dependant on several things, colour, production line etc, such that one that left the production line first may have a higher number than one that left later. In other words, the numbers aren\'t sequential and are not specifically related to date.
That might be wrong, I\'m only repeating what I was told!!
andrewrx7
QuoteOriginally posted by JVS RX7s
Have a look here. A very good summary of the models including RZ\'s and production numbers.
http://www.rx7.net.nz/fd-jp-models.html
JVS RX7s
Thanks,  its not as clear as i wanted but what can you do....
anything to avoid the SVA ;)
sadgoth
this may also be of help a guy on the US site was trying to date his JDM car which he thought was an RB
http://www.rx7club.com/showthread.php?t=349824
Mark
Loud? Hell yes! :D
