Track Rod Ends,
Started by ro284, March 19, 2005, 05:26:28 PM
ro284
My rubbers have perished on the Track Rod Ends, is it possible to get new rubbers? anyone know? there is no wear in the joints yet, but m.o.t. coming up! will i have to replace the swivel joints, and are they expensive? any help or advice gratefully recieved.
cheers Bob
Hi Bob,
Even though l am sure you can\'t change the rubbers anyway, l wouldn\'t expect a joint with a split rubber to last long as the damage is probably already done with water washing the grease out and road grit n gime contaminating them.
Replacement joints should be quite cheap anyway.
gsb876
Mine are going to be done in the next week or so, i believe they are £35 each for the TRE :)
