Single V\'s Twin
Started by Mr_7, December 21, 2004, 12:37:44 PM
Mr_7
This topic has probably been covered many times but i would like to know the pro and cons, also what is obtainable on a twin turbo set up and why convert?
Mr_7
Gman
Mr_7
Thanks fo the link Gman but its not technical enough for me. Im really looking to find out why people go down this route and why the twin turbo set up isnt enought eg it can hold the boost etc. I dont understand why the single big turbo is so sueful for big power is it because the area is to cramped for the twins what please help?
20B_boy
Eh?
The stock turbos produce a lot of heat and not much else much over 16psi and often die fairly soon afterward. If you want 320whp+ you need a turbo than can shovel in a lot more air than the stockers can pump.
R.
scooby_si
my understanding as a simple way of putting it from a simpleton is that the twins are basically 2 quite small turbos so running say for agruements sake 1 bar thru both both with be way less power than 1 bar thru some big MAHOOOSIVE singlehttp://www.smileycentral.com/?partner=ZSzeb008_ZS\' target=\'_blank\'>http://smileys.smileycentral.com/cat/10/10_8_3.gif\' border=0>
Si
Mr_7
If this is the case that the turbos spool up to early and therefore have reached full boost erarly in the rev range surley if you change the degree of the impellers you gen get it to spool up later and with more boost as a result what are stock engines boost?
sadgoth
surely if you increased the size of say the second turbo (I understand the physical lack of space issue) to something say GT25 or poss GT30 sized (if it would fit) but kept the sequential setup so you have the quick spoolup time you could get the best of both worlds? Or if you fancy doing some serious enginebay re-organising two GT42Rs in a turbo pack :D ok yo\'d probably have to lose the passenger seat but.....
Mark
89 Black FC3S Turbo II
Loud? Hell yes! :D
20B_boy
QuoteOriginally posted by Mr_7
By the time u re-engineer the stock turbo pack you\'ll have spent more than a single turbo kit would cost - and to the same end? waste of time.
R.
Mr_7
so what is the stock turbos size?
and also what does each turbo boost at when origina? (is there still an original Rx out there lol)
Gerry M
are both the stock turbo\'s the same size flow rates etc?
The tartiest rx in scotland
