What battery to use?
Started by hot RX, December 27, 2004, 03:16:04 PM
hot RX
Anyone know if a stronger than standard battery is required to start an FD3?
My battery is fully charged and I am trying to see (after the xmas break) whether my starter motor, earthing, battery or alternator may the the cause of my having to jump start my car on 3 occasions now.
If a jump start works it can\'t be flooding or the alternator right?
The battery is NOT draining either.
I always have cables in the back just in case!
What battery do others on the forum use?
Anyone changed the starter motor or fixed an earthing problem, where their car starts well now?
rx7veilside
u must have a fault somewhere mine was starting fine with the smaller battery that is used for a fmic
hot RX
ok, thanks, must be an electrical fault (wiring, coorosion or somethng) Will get the car checked out with an auto electrician.
hot RX
yep it was a bad battery that never fully charges up as 30 percent of the cells were effectively dead. I had a full electrical diagnosis and nothing else was wrong! so...I have peace of mind, a new battery and now the car starts 100% of the time, no problems. Thanks for everyone;\'s advice.
Good to hear that everything is back working ok.
