Boost controllers and Fuel Cut defendars
Started by Steve Burnett, December 12, 2004, 12:57:04 PM
Steve Burnett
This is kind of a continuation from another thread. Instead of hi-jaking it I thought id start a new one.
Okay so the boost controller stops the car overboosting but why fit one if all it does is cover up a problem?
Or is it really a safety device to stop boost spiking in the event of it happening.
Also what does a fuel cut defender do? I just bought a Knightsports one. I think I have an idea but not to sure.
bobster
Fitting a boost controller doesn\'t really cover up an overboosting problem but could cure it. It depends on what is causing the problem.... you could have a leak in the vac lines that go to the wastegate actuator, then the wastegate wouldn\'t open.... so the turbo just keeps spinning up.
The PFC (using the stock solenoids) is as good at controlling the boost on a modified car as a turnip would be. Having said that you could probably shove the turnip up the exhaust to give you some back pressure.  :rollin
The FCD will stop the ecu from cutting the fuel when you hit the speed limiter the stock ECU has in it. This cuts the fuel when you hit 180km... whatever that is in british money. This is built into all JDM cars under JDM law.
I honestly couldn\'t tell you if the FCD will also stop the fuel being cut when you hit the rev limiter or overboost the car. But in my opinion there is no such thing as "overboost".... just throw in some more fuel and make use of it :rollin
Blitz
I believe the FCD cuts fuel when you hit a certain boost level.
20B_boy
QuoteOriginally posted by Blitz
It does the opposite, PREVENTS fuel cut when the boost goes up.
R.
MikeLMR
so you better make sure its got enough fuel to cope with that boost otherwise its :wave  engine.
The fuel cut is there to stop you from overboosting (not that it does the engine much good!)
bobster
QuoteOriginally posted by 20B_boy
But if you were winding the boost up you would put an ECU in...... unless you have deep pockets for a new lump.
I\'ll stick with my Speed limiter explanation being its main function..
20B_boy
R.
Blitz
LoL, exactly, thats what I meant to say. DOH!
bobster
We on about the same things Bob?
Probably...... I\'ll shut up now :D
20B_boy
Cool, I\'ll shut up too then ;)
Trust all is well in bonny jock-shire :)
R.
