300ZX Wheels
Started by scoobster, December 01, 2004, 08:03:01 PM
scoobster
I have been looking for a set of second hand wheels and i have found a few sets for sale for the 300ZX, as far as i can find out the offsets are about the same and the use the same PCD but the only problems is the the hub c/bore is 66 for the 300
Are all wheels centres a common size and you just need the correct spigot rings to reduce this down to the 59.5 i would need to fit an FD?
:cheers
shaunwil
You could find a machine shop in your area with lathes and get them to make you some rings to suit as long as the rest is ok. Wouldn\'t be a big job either, could be turned from tube. It is the case that they will be a slack fit on the mounting hub ?
Just have a ring round and somebody should be able to help. Kelly seach is a good place to start.
Shaun
scoobster
Yeah the centre hub dia on the nissans are 66mm but from what i can tell the FD\'s are 59.5mm so are 6.5 mm smaller:(
i got a set of spigot rings for some 18" wheelmania wheels for my skyline and they had a 66mm centre bore but i\'m not sure if you can get 59.5mm centre bore spigots that would fit the same dia bore in the back of the wheels if you know what i mean :confused:
shaunwil
Best bet is to get some machined if nobody makes them. Could get them done in stainless 304 without too much hassle.
Just a fag packet drawing should see you though ! :)
Shaun
shaunwil
Out of interest how much would they cost for a set and how wide are the back wheels ???
Shaun
scoobster
Well theres a set of 18" with new tyres for £700 and i think the rears were 8.5 inch.
It\'s just i can\'t find any wheels for sale for the FD that i like (but if anyone has a set of BBS LM\'s for sale for a 3rd gen let me know  :D   ) so thats why i started to look at other makes
