installing 1600cc injectors
Started by davehg, November 29, 2004, 08:04:49 AM
davehg
does anyone have any diagrams/pictures etc that will help me to install my new 1600cc injectors and fuel regulator???
thanks
in advance
asp
its quite easy really,the hardest bit was takin the fuel reg off, no alan key no 10mm bolt flippin philips skrewdriver stuff, make sure ur philips bit is the right size,i rounded 1 of mine while takin mine off,tryed mole grips no good, had 2 get a small haxsaw blade n cut a flat skrewdriver slot onit 2 get it out,i think after i got it off i replaced them with allan key things
asp
Follow this link and it will give details on it.
rxrotary2_7
in the link Fish provided, the *old* method of sealing the injectors has been addressed with sleeves that slide into the manifold. you can find them here: http://www.kgparts.com/diy.htm
