ARC Induction Box
Started by scoobster, November 22, 2004, 10:09:33 PM
scoobster
I have just got my ARC induction box but all the instructions are in japanese :eek:
I know the fitting of the box will be easy enough but looking and the photos in the instructions it refers to a multi plug and making a loop from the GND terminal and another terminal but with it being in japanese i can\'t tell which one and why it needs to be done
Anyone got any ideas?
mattmaclennan
the only ARC boxes I\'ve seen don\'t require you to mess with the loom... and without being a meanie... are crap. They suffer from heat soak and the filter in the bottom of the air box just draws boiling hot air straight off the radiator. The filter panels get so dirty so quickly, the car underperforms horrificly. But what do I know, it could be some all new sing and dancing air box that has none of these characteristics!
bnaellis
QuoteOriginally posted by mattmaclennan
No wonder you guy\'s aren\'t answering the phone too busy surfing.:D
Scoobster this is true it\'s the worst induction kit you can get for the rx7. If there is such a word as anti-performance mod then this is it.
rgds
Donato
Tis very ture, i had one and it was CRAP! Im now using it to hold dust in the garage....
Donato
Sorry that wasnt very constructive, especially as you have just got it, if you are going to use it i would suggest getting some heat sheilding around it, perhaps the stick on stuff...
when i had my arc box fitted the panel filter was facing up the way, all thought the panel filters do need replacing quite quickly.
Im sure user name - Millspeed has one so might be an idea to speak to him about fitment...
Donato
scoobster
Cheers Guys, i didn\'t get it for performance it\'s just for looks as i don\'t want to mess with the engine like i did with my Skyline as once you start the spending just never seems to stop :eek:
Cheers Anyway:D
