Arh, Power FC what are you doing to me ????
Started by shaunwil, November 14, 2004, 02:04:23 PM
gsb876
If you have no luck go and see Pip, only down the road from you Shaun.:)
Better to have it done properly than second guessing matey??:(
shaunwil
That is a good point, it was going to get booked in to get the apexi tuned to the car but i wanted to get the idle setup and the unit in the car before i took it to pip. I\'m going to ring him and find out what i should do.
jonrx7uk
Shaun,
When i installed my PFC a month ago, the idle was all over the place (wouldn\'t stop surging).  What i did was wind the idle speed screw in (located under the plastic intake elbow) to just about close it.  Reset PFC and started again.  Idle is rock-solid now.
Also check clutch switch, the dot on the commander should go on/off as you operate the clutch.  If broken, i mended mine with a ballpoint pen spring!
Let us know
Jon
shaunwil
Cheers Guys, just been adjusting my Throttle Position Sensor and re-done the process again (lost count) and it seems to be working ok. Ticking over at 800 rpm (not too bothered about 50rpm at the min). Nice and solid and the sensor is showing 0.47 on VT1 and 1.1 on VT2 and is all in the green. I\'ll keep an eye on the voltage to see if the sensor is slipping and then it should be fine. I\'ll take it out in a bit to see what its running like. At least there are no errors flaring up, so hopefully all is well :)
Cheers for all the great help, much appriciated. Shows just how good this club is (extremely good !!!)
Shaun
Freddy
Good stuff Sean, hope the drive went smooth. :)
so thats Reason Number ** To Join MRC!  :D
Freddy... (off to get his c/q book, do they do NUS discount? :confused: )
