12a Dizzy To 13b
Started by KJK, October 24, 2004, 07:12:53 PM
KJK
ANYONE KNOW IF I CAN FIT DISTRIBUTER FROM 12A TO 13B , AND ALSO WHERE I CAN GET AN INLET MANIFOLD 4 TWIN WEBERS
travellinbob
I thhink it depends on you timing cover. I had a 13b six port engine in oz running a 12aturbo front timing cover and therefor a series 2(first gen) electronic distributer. I basically did this so that I could use a fuel only computer. Why are you going for a twin weber manifold? Why not a single 48mm down draft.?
KJK
WANT TO USE DIZZY IF POSS TO KEEP IT CHEAP , RATHER SPEND ON REBUILD &PORTING ,THAN EXPENSIVE MANAGMENT MAPPING
Carl
Simple answer is yes as long as you have the right front cover on the 13b.
Kind regards
Carl
